Help with Video Card
NFarnzy
I have a Palit Gtx 560 Ti and I am getting artifacts. This is after I have had it over clocked from stock to 900mhz. It has been working great for a couple weeks and all of the sudden.. there are some issue's coming. The errors.. the Nvidia drivers are coming on. I uninstalled them and reinstalled them.. didnt help. ..still getting errors.. then I backed off the O/C and went stock on all of it. That didnt help either. The O/C settings was 1025mV Core clock 900mhz, shader clock 1800mhz , Memory Clock 2050mhz and Fan % was 60% all the temps was all good.. running no higher than 70c. Is there anything I could do.. settings that I could change to fix the issue?
Can still use the PC while surfing and what not.. but when I go to load up a game.. the nvidia drivers crash. the screen goes black then comes back on, a balloon popup from the bottom says something like nvidia driver encounted an error and had to be restarted. What would cause that issue?
Win 7 Pro 64bit Sp1
i2600k @ 4ghz 1.3v
Seasonic x650w
Antec 900 PC Case
