- Nov 20, 2001
- 1,736
- 0
- 0
I'm building a new system in the next 2 weeks and I do not upgrade often (current system is a C2D with a 4870, which is 3 years old). New system specs will be i2500k and z68 (with both CF and SLI support... haven't played with either since SLI 6800gt back in the day).
I play at 1080p and prefer high settings with AA/AF. I play just about everything, (currently Witcher2, DX:HR) and plan to have Skyrim and BF3 take over my gaming life soon.
I had pretty much settled on a 6970 because I would prefer to have the 2GB of memory going forward. But after looking around, I am considering other higher options-- even CF.
So, at a minimum, I am looking at a $300 6970. I can't say "money is no object", but, at the same time, increasing the budget to a $430 580 is not a problem. I'm just looking for good performance that will last me a while.
Some of my options look like:
6870 CF for about $320 (better performance than the 6970 but 1GB memory vs 2GB
6950 2GB CF for $540 (a good 60% in cost vs 6970 but also around 60% perf increase)
580 for $430
There's probably some other options in there as well, such as SLI 560, etc. Lotta cards out there. I know power usage on these setups can get high, and I will be reusing my Corsair 750w PSU, so I won't be able to go crazy with the ultra high-end SLI setups.
580 for $430
