- Oct 19, 2001
- 304
- 0
- 0
Hello,
What I have
HP Pavilion 513x with AMD Athlon XP 1600 with 256megs of DDR a CDRW, DVD ROM, Integrated (but can be disabled) 32 meg DDR Prosavage video card, and an ATI PCI All In Wonder 128 with 16 megs of ram.
I hooked a 17" Monitor up to the 32Meg ProSavage Card and a 19" Monitor up to the ATI All In Wonder card.
Under normal operation, with the Prosavage card set as primary display and the ATI as secondary, I don't have any problems. I can see both desktops, can drag icons across both displays, etc.
However, when I try running Return To Castle Wolfenstein, it fails, which normally doesn't, because it can't decide which display to open up with. The same thing happens with the TV Tuner.
For wolfenstein, if I deactivate one of the video cards by disabling the desktop, the game runs fine on either card. But it only works if I only have one card active.
its similar, but otherway around, for the TV Tuner. If I have the ATI card set to primary, which I don't want, because I want my desktop and start menu to be on the other monitor, .... if I have the ATI card set to primary, the TV tuner will launch fine and I can watch TV. If I set the ATI card to secondary, the TV tuner fails because it tries to open up and run on the Prosavage card.
My question is, is there any way to tell a program which display to use?
What I have
