I just tried to get my scanner to work on my new rig. How to I make sure that the onboard usb ports are connected. I do not think they are up and running as I can not see them under system devices. Rig specs:
T/bird 1200/266
Iwill KK266
40 GB IBM Deskstar
Win2k SP/2 OEM
Gainward G/Force GTS Pro/450
Plextor 16x CDRW
Toshiba 16x DVD
I am trying to install a Visioner 6100USB. I went to their site and downloaded the Win2k drivers and they are in the regeistry. I go to load the device through add hardware and no go. I checked the BIOS and set it to PNP/OS but I could not find anything in the BIOS to Enable/Disable USB.
Any help would be appreciated.
Thank you.
T/bird 1200/266
Iwill KK266
40 GB IBM Deskstar
Win2k SP/2 OEM
Plextor 16x CDRW
Toshiba 16x DVD
Thank you.
