Help with Upgrading to Gaming PC?
richdog16
16
If I buy a AMD Athlon 250 x2 3.0ghz and a GTX 550ti will it be enough to run mordern games at high settings?
fralexandr
2,281
222
www.flickr.com
that depends on what resolution you plan on playing at
most modern games at 1680x1050? sure, all? no, some games like crysis or battlefield 3 are pretty demanding
a lot of games are moving to quadcore, so a quadcore (or at least quad threaded) cpu is recommended
Puppies04
5,909
17
What do you class as modern games? If you are talking about Battlefield 3 then forget it, a 550TI is nowhere near enough.
Now if we were talking low/med @1080p you might get a more positive answer. As for the CPU it really depends on the game, anything CPU intensive is going to give you trouble but it should handle most games ok.
mfenn
22,400
www.mfenn.com
We need more context to make a good recommendation. As others have indicated, what types of games are you interested and at what resolutions? What is your budget? Are you paying retail for those parts or getting them cheap from a buddy? What hardware do you currently have?
