aweaver255
I'm wanting to upgrade to the M.2 SSD going with a PCIe adapter, specifically seen here: http://www.newegg.com/Product/Product.aspx?Item=N82E16820104544
While I understand a few things, some questions still remain, and would also like anyone's input if they're using a configuration like this, if at all possible that is.
What I know:
1. The 990FXA-GAMING mobo- PCI_E4 supports up to PCIe 2.0 x4 speed
2. The product with adapter is PCIe Gen 2.0 x4 interface in M.2 form factor
3. This config is much faster than your typical SATA III SSD
Some Questions:
1. Does anyone have any input on this?
2. Would I be able to use this product with my current rig?
3. Is the mobo compatible and will it support it? (I have yet to hear from msi-tech support)
4. Would I be able to put the OS on it and boot?
5. Problems/Errors/Detection/Performance Info or Input from anyone using this type of config?
My Rig:
MOBO: MSI 990FXA-GAMING
CPU: AMD FX-8350 4.5GHz @ 1.55v at 51°C
PSU: EVGA 700B1 Series 700W
RAM: Crucial Ballistix Elite 32GB (4 x 8GB) DDR3-2133 Memory @1600MHz
Cooling: Corsair H80i GT push/pull, 140mm(x2), 120mm; GPU Liquid Cooled w/ 120mm(x2) push/pull
SSDs: Crucial BX200 240GB (X2)
HDDs: Toshiba 1TB 7200RPM (X2)
GPU: EVGA GeForce GTX 980 Ti HYBRID GAMING OC'd to 1.49Ghz @ 58°C
CASE: Corsair SPEC-03 Red
What I know:
Some Questions:
My Rig:
