Using the utility to make answer files, I created an unattend.txt and unattend.bat file within a distribution folder.
A website on this subject tells me:
<< A distribution folder is created to do an installation over the network. An unattend.txt answer file and a unattend.bat file, for starting the installation, is created by the Setup Manager.
Booting from the network involves:
Have a network card in the computer the installation is to be done on.
Format the hard drive.
Boot a computer with DOS client for Microsoft Networks on it (Comes With Windows NT Server).
Map the shared distribution folder to a network drive, and from that drive run "unattend" or "unattend computer"
Well, I want to start the installation from the hard disk AND use the distribution folder (so I can auctomatically install unsupported drivers). I tried to edit the unattend.bat file to something that would run locally, but it performed a regular, attended installation. I also understand that I can put the answer file on disk as winnt.sif and boot from CDrom.
But can I install with a local distribution folder?
Thanks.
Thanks.
