Originally posted by: armatron
okay this totally isn't in my book.
f(x)=5
f(x)=(x)/(x^2+4)
f(x)=7x^2-4x+28
f(x)=3^(x-1) + 2
f(x)=x+3
f(x)=5
f(x)=(x)/(x^2+4)
f(x)=7x^2-4x+28
f(x)=3^(x-1) + 2
f(x)=x+3
1) constant
2) 2nd degree poly
3) same
4) linear (1st degree)
f(x)=5
f(x)=(x)/(x^2+4)
f(x)=7x^2-4x+28
f(x)=3^(x-1) + 2
f(x)=x+3
1) constant
2) 2nd degree poly
3) same
is 5 constant?
what makes:
f(x)=7x^2-4x+28
second degree, but :
2x^3+7x-15
just a 'polynomial'?
f(x)=5
f(x)=(x)/(x^2+4)
f(x)=7x^2-4x+28
f(x)=3^(x-1) + 2
f(x)=x+3
1) constant
2) 2nd degree poly
3) same
is 5 constant?
what makes:
f(x)=7x^2-4x+28
2x^3+7x-15
Second degree = has an exponent of 2
The 2x^3 + 7x -15 does not have an exponent of 2 and hence is not a second degree..
f(x)=5
f(x)=(x)/(x^2+4)
f(x)=7x^2-4x+28
f(x)=3^(x-1) + 2
f(x)=x+3
1) constant
2) 2nd degree poly
3) same
is 5 constant?
what makes:
f(x)=7x^2-4x+28
2x^3+7x-15
f(x)=5
f(x)=(x)/(x^2+4)
f(x)=7x^2-4x+28
f(x)=3^(x-1) + 2
f(x)=x+3
1) constant
2) 2nd degree poly
3) same
is 5 constant?
what makes:
f(x)=7x^2-4x+28
2x^3+7x-15
Thanks for pointing it out. I hoped the OP would get the hint of the trend.
BTW, when you compound the interest, maybe you should add that amount you obtained to your initial investment
okay stuck again on these stupid problems that I learned 4 years ago.. arg
$1500 invested at 6.25% compounded continuously. What is the balance after two years?
A=Pe^(rt)
A=1500e^(.125)
ok
do I then go
A\1500=e^.125
A\1500=ln e^.125
A\1500=.125
A=187.5
Now, I know that $1500 after 2 years at 6.25 doesn't equal... 187.5. so what am I screwing up here?
A=Pe^(rt)
A=1500e^(.125)
ok
do I then go
A\1500=e^.125
A\1500=ln e^.125
A\1500=.125
A=187.5
When you took ln of the e^.125, you didn't do it for the left hand side of the equation.
You pretty much have this thing solved when you wrote A=1500e^(.125). Just do that on your calculator to solve for A.
f(x)=5
f(x)=(x)/(x^2+4)
f(x)=7x^2-4x+28
f(x)=3^(x-1) + 2
f(x)=x+3
A=Pe^(rt)
A=1500e^(.125)
ok
do I then go
A\1500=e^.125
A\1500=ln e^.125
A\1500=.125
A=187.5
$1699.72
awesome.. and that includes the initial amount
Thanks man
A=Pe^(rt)
A=1500e^(.125)
ok
do I then go
A\1500=e^.125
A\1500=ln e^.125
A\1500=.125
A=187.5
$1699.72
Thanks man
Yep, subtract off 1500 to get the interest.
A=Pe^(rt)
A=1500e^(.125)
ok
do I then go
A\1500=e^.125
A\1500=ln e^.125
A\1500=.125
A=187.5
$1699.72
Thanks man
okay... how about the same problem but compounded quarterly rather than continuously?
A=Pe^(rt)
A=1500e^(.125)
ok
do I then go
A\1500=e^.125
A\1500=ln e^.125
A\1500=.125
A=187.5
$1699.72
Thanks man
A=Pe^(rt)
A=1500e^(.125)
ok
do I then go
A\1500=e^.125
A\1500=ln e^.125
A\1500=.125
A=187.5
$1699.72
Thanks man
I got this answer $1693.359
what I did is 1500*(1+.0625)^2
Originally posted by: notfred
What class is this?
A=Pe^(rt)
A=1500e^(.125)
ok
do I then go
A\1500=e^.125
A\1500=ln e^.125
A\1500=.125
A=187.5
$1699.72
Thanks man
The problem means compounded continuously, not compounded annually.
A=Pe^(rt)
A=1500e^(.125)
ok
do I then go
A\1500=e^.125
A\1500=ln e^.125
A\1500=.125
A=187.5
$1699.72
Thanks man
yes.. but the next problem is "okay, now compute if interest is compounded quarterly"
and the final might have "yearly, bi-yearly" or who knows
