Help With TweakNow RAM Idle LE
trigun500
I just downloaded the RAM Idle program and in the "My Memory" Tab it says:
Memory Load 33%
Total Physical Memory 2048 MB
Available Physical Memory 2047MB
Total Page File 4095 MB
Available Page File 4095 MB
Now I have 4 gigs installed on my system (with Vista 32 bit) is my system recognizing all the memory?
Is there anything I can do to optimize?
dude, wait a bit longer before bumping.
Anyway, hit ctrl-shift-esc and bring taskmanager up. Go to the performance tab. How much does it say you have?
Assuming you really have AND see 4GB, there is no need to optimize. Vista will use some of your RAM to pre-load programs.
If it says you have less than around 3-4GB RAM, then run Memtest86+ overnight.
