Help with this thing
Anubis
i just Dl and installed the seti thing and was all posed to give y fellow ananders a helpin hand cept everytime it is running my comp will be foinr for about 2 minutes then it will freeze. only dose this when seti is running. womeone please tell me why its dooing this and how to fix it
Describe you rig and OS and such. 😉
Actually, I just looked at your rig. You are OC right about the go nogo point. What are your temps? Back off a little on the FSB and see if that helps. SETI will freeze a computer that is operating on shaky ground.
im runnin an XP 1700+ @ 1.570 GHz EpoX 8KHA+ mobo running win 2k. 64 med ddr readon VIVO SB Sudigy other crap. have all the windows updates and such dont really know what the problim is
What are your temperature readings of your CPU? If they are above 50C you might have to slow it down a little. 😉
Yeah, I'd say back down the OC a little. You've got plenty of power there. Be a little conservative till you get seti stable. Let us know how it goes.
Definitely back down on the OC.
When I first installed Seti on my Epox8KHA+ with an Athlon XP 1600+ I had the FSB at about 146-147. Seti refused to run.
So, I backed the FSB back to 133 and then slowly brought it back up till the system ran stable with Seti.
I now have the FSB at 143 and the processor at 1.5 Ghz and everything is running happily.
Good Luck!
ok backed OC ing to almost none 11x136. right now. id like to get it to 11.5x133 if i can but ill see what i can do about that. for now wanyway its workin and im helpin my anand boys out
