Hello, I just got a celeron 566 and an ABIT sloket and installed it onto my ABIT BX6 REV2. I set the voltage to 1.75 (hoping to overclock soon, just after a couple of tests) on the sloket itself but did not overclock the chip. So i am running at 66mhz bus at 566mhz.
Anywaz, everything worked fine until about 3 hours later and then all of a sudden my mouse wouldn't move and my computer would freeze IN SPURTS...then it would go back to normal. For example, I would just have icq, winamp open and like when I an incoming message came in, I would try to open it and then all of a sudden, my mouse AND computer like froze, then moved, then froze, then moved back to normal.
THIS also happened in Counterstrike too at randmom times. I was about to fire, then it paused, then one shell came out slowly then paused again and then it fired normally and the game ran normally for about 2 mins until it happened again.
SO, I have since then, put the voltage back down to 1.5 volts and it is still happening. Does anybody know why this could be happening?
***NOTE: When I bootup, during the VERYFIYING DMI POOL...., IT USED TO SAY "..SUCCESS" but now it doesn't and just goes on and normally boots up into window.
