Help with SQL query
Kntx
2,270
Ok, so here's what I have.
2 Tables with columns... Jan, Feb, Mar, Apr... etc.
I want to sum the columns of each table with the sum of the colums of the other table. In the end I would like to return one row which is the totals for each month.
This sort of illustrates what I would like to be able to do with each column...
sum(select Jan from Table1 union select Jan from Table2)
Thanx for any help!
mugs
48,920
46
wait... Jan - Dec are the only columns in the two tables, or is there another field that identifies the record?
