Depending on which version you have ABR or BR the screens will be different but what your looking for are Virtual Server or Special Applications. If you use virtual server, then that port will only be passed to one computer. If you use special applications, all computers will be able to use that mapping, but only one computer can use it at a time. For virtual server, you just put in the computer ip and the to/from ports. For special applications, you put in an outgoing trigger port and what ports will be opened when that port is triggered. There isn't a way that I know of to pass one port all the time to every computer. If all else fails you can enable DMZ but you should make sure your computer is secure.
