help with setting up SCSI RAID0
enclavesaga
40
hello fellas,
I recently grabbed a pair of 36GB, and 1 18GB Fujitsu SCSI U160 15K HDDs, planning to get a Adaptec ASC-29160N, what i am not sure is how to set them badboys in RAID0 format, do i have to get another RAID controller? I am new to SCSI, can someone post a simple walkthrough? I like to put my system in the 18GB and run the pair of 36 in RAID0
Thanks
alzan
3,860
Well, the 29160N is a SCSI controller, not a RAID controller. You could use the 29160N for attaching the drives then, depending on your OS, set up a RAID0. However, you'll take a performance hit by running software RAID.
Depending on your budget and system performance concerns, a hardware RAID solution would be better.
alzan
