help with setting up IIS
i need to set up multiple websites on an intranet server
i need them to be truely virtual though
for example, http://server/website1/ serves up a directory as the web root
(so a link on http://server/website1/index.html that links to "/" will point back to http://server/website1/ - not back to http://server/)
its for a test/development server
...the multiple webroots is important, and i only have one machine, and one IP
machine is windows 2000 pro, with IIS 3.0
i may be able to get IIS 4.0, but only if its absolutely needed
please help :)
yeah, it is IIS5
i was mis-informed
sorry
i still can't figure out how to get multiple sites though :(
Workin'
5,309
<< Unfortunately with only one IP you are in a pinch. >>
No you're not. Just use host headers to create the virtual sites. Look up how to do it in the IIS help files. It's really, really easy. I mean really easy. Did I mention it's really easy? IF you have Windows 2000 Server or better.
HOWEVER - the problem is you have Windows 2000 PRO - that means that IIS can only host ONE web site, virtual or otherwise. You can have 50 IP addresses and still only host 1 site using Win2k Pro.
you need a server version of Windows 2000 to host multiple web sites.
If you don't need support for VBScript, ASP, or Access databases, then Apache might work well for you. It's free and extremely powerful and flexible.
