Help with setting up Epox 8K7A fsb to 133
briddle
590
First off, I am not into overclocking and this is my first epox board. I have been using msi pro2a and turbo (133A) and the turba is a simple moving the jumper setting on a single jumper. I am not used to seeing all these jumpers and will admit to not being a very good read on the manual, but as I followed some of the talk, you maybe should not setup like the manual anyway.
It comes set up to a 200 fsb default, which makes my 1333 (266) show up as a 1000. cpu jumper is pins 1-10:
1 6
2 7
3 8
4 9
5 10
The number 6 has a jumper on it and the 3 & 8 are jumpered. In laymans terms, how should the jumpers be moved??
Also having an onboard audio problem, bios seems set up, but audio drivers do not want to install??
Help please
Thanks, Bruce
Gracki
20
not to be a wiseass but the manual is very clear about that jumper. This jumper is the ONLY one that needs to be moved. Just look up the FSB jumper in the manual and move it over. I think that the one you are describing is the ratio or vcore jumper. If I remember correctly the FSB jumper was just a series of three pins and the jumper had to be moved to 2-3 from 1-2. The manual is pretty shady, but trust it on this one...
-Greg
Zuluwarrior
252
Jumper is JCLK1 and should be
jumped on 1 and 2 pins
default is 100fsb which is 2 and 3 pins......
You should consult a medical professional before taking this advice
