im trying to setup djbdns but its kicking my butt since im not too good with *nix systems. ive unzipped it and it here is the instructions i got from the page:
Installation
Download the djbdns package. The latest published djbdns package is djbdns-1.05.tar.gz.
Unpack the djbdns package:
gunzip djbdns-1.05.tar
tar -xf djbdns-1.05.tar
cd djbdns-1.05
Compile the djbdns programs:
make
As root, install the djbdns programs under /usr/local:
make setup check
Now you can configure a local cache, an external cache, and a DNS server. If you're not familiar with djbdns, you should start by reviewing the standard configuration and, if you're behind a firewall, the standard firewall configuration. If you're not familiar with the Domain Name System, you should start by learning how DNS works.
Once djbdns is running, you should report success in two ways:
Send me the portability notes created by the compilation process:
( echo 'First M. Last'; cat `cat SYSDEPS` ) \
| mail
djb-sysdeps@cr.yp.to
Replace First M. Last with your name.
Set up a public web page saying that your server is powered by djbdns, so that a Google search for powered djbdns will find your page in a few months. These public statements will encourage other people to deploy djbdns, provide djbdns support services, and develop djbdns-related tools.
after unzipping.. there are tons of c files.. which do i compile? there is no file called 'make'
