Help with Seagate 7200.9 Hard Drive
Trikat
3,384
I noticed that SMART reported a few WATCHes and recommended me to change the hard drive immediately.
I ran the Windows XP Check Disk - Checked Auto fix errors and checked scan for and attempt recovery of bad sectors.
I also ran Seagates Seatools (Independent OS - Desktop) and it found a long list of errors and SKIPPED.
Using WD's quicktest on the Seagate failed.
I'm thinking the only thing I can do right now is RMA the hard drive as it seems like there is no way to recover/fix/replace the damage. Do you guys agree?
Link_to_SMARTPIC
NOTE : your hard disk has 88 reallocated sectors. Hard disks do have spare sectors (usually from 256 up to 1024) used to replace bad ones. This remapping operation is transparent to the end user. Anyway, this can lead to degradated performances (because remapped sectors are in different places of the disk than the original ones and the head needs additional moving). If reallocated sectors grow over time, you might encounter some serious troubles. A backup of the most important data is suggested anyway.
NOTE : your hard disk has 159 pending sectors (this value is very large and your hard disk should be replaced). Those are sectors that couldn't be properly read and that the hard disk logic is waiting for a write operation to try to remap to a spare sector (if available). According to the Reallocated Sector Count attribute, your hard disk seems to have available spare sectors. A simple disk surface scan won't be enough to force the remap operation. You need a read/write surface scan to remap the sector. The best option should be a tool that knows about what should be read from that sector so that it has some option to apply the best fix to the missing data.
NOTE : your hard disk has 159 offline uncorrectable sectors (this value is very large and your hard disk should be replaced). Those are sectors that an offline scanning found as unreadable. Offline scanning is a process that can be automatically started by the hard disk logic when a long enough idle period is detected or that can be forced by some tool. Those unreadable sectors are identified and the hard disk logic is waiting for a write command that will overwrite them to try to remap them to spare sectors (if available). According to the Reallocated Sector Count attribute, your hard disk seems to have available spare sectors. A simple disk surface scan won't be enough to force the remap operation. You need a read/write surface scan to remap the sector. The best option should be a tool that knows about what should be read from that sector so that it has some option to apply the best fix to the missing data.
The overall fitness for this drive is 62%.
The overall performance for this drive is 89%.
Boyo
1,406
It's a bad HD. I would RMA it because you aren't going to be able to fix it.
John
Moderator Emeritus<br>Elite Member
4
Trikat
3,384
Shouldn't the 159 uncorrectable sectors be replaced / ignored? Did the Check Disk - scan for and attempt recovery of bad sectors and the Seagate replace/ignore the bad sectors?
When I ran those tests it did not say anything about replacing/ignoring the sectors. Which program should I use to do that or will I need to format the hard drive to have the sectors replaced/ignored. Thanks.
I just don't want to RMA it soon as I will need to back up my files and this is a 300GB hard drive. :/
