Help with SB live and win2k
leighd8
671
I just upgraded to win2k and my SB live +mp3 isnt working the way it was in win 98, i went to the website and downloaded live ware 3.0 and i cant install it. there is a setup.zip file and 4 other zip files. everytime i try to use theses files to install it tells me i havent downloaded all the files. please help
nemouk
433
You should have 5 files in all.
4 LW2KDRV*.LIB files from 0 to 3.
1 Setup.exe
Place all the *.lib files in the same directory as setup, and run it, thats all i had to do.
leighd8
671
That is where i got it from yet i cant install it
i have 0-3 and setup, i unzipped all the drv (0-3) into a file called c:temp\ then i put the setup.zip file there and unzipped it and installed through winzip yet it still claims i donthave everything?????
Ulfwald
Moderator Emeritus<br>Elite Member
May 27, 2000
8,646
You first have to unzip all files to one, then run the setup which will merge all the files into one. If this does not work, email me your snailmail address and I will send you a copy on cd.
