Sulaco
Hello everyone,
I'm trying to help my brother resolve a problem with his PC. He's running:
Asus A8N-E (s939)
A64 X2 4400+
Windows Vista Home Premium 32
200Gb Seagate SATA
He's had no issues or problems with it of any kind since getting it.
...anyway, here's what happened:
He says he resumed his computer from sleep mode, and within a few seconds, everything froze, all the icons disappeared from the desktop, and an error message saying something about "logic drive" or "Logic driver" not being found or not working properly. He shut the computer down shortly since everything was locked up.
Upon starting it up again, Windows fails to load. He gets a "No system disk or disk error, etc" message in BIOS.
Upon entering BIOS, the IDE optical drives are detected, but the SATA drive fails to show up in any of the boot.
I swapped in an old IDE HDD he had lying around with Windows XP installed, and it was recognized in BIOS and loaded up just fine.
I then took the problem drive, the one BIOS refused to recognize, and tested it on another machine to see if I could retrieve his data. Sure enough, as soon as I plugged it in, the other computer detected it in BIOS and I was able to salvage his important data.
But unfortunately, his computer still fails to detect the SATA HDD.
So far, I've:
--Swapped SATA cables
--Plugged the SATA drive into every available SATA port on the motherboard (4)
--Inserted the Vista DVD and tried a Startup Repair option (no go, didn't see the drive or partition)
He claims not to have plugged in any foreign USB devices recently, as I figured that might be the issue.
Tomorrow I plan on unplugging all USB devices and resetting CMOS before trying again.
But does anyone have any idea what this could be? The HDD works fine in other computers, and it runs/detects IDE HDDs just fine. But for some reason, SATA seems to have just vaporized.
Any ideas would be greatly appreciated! Thanks!
Asus A8N-E (s939)
A64 X2 4400+
200Gb Seagate SATA
So far, I've:
