Ok, so I recently upgraded my computer. New CPU, new motherboard, Soltek SL-K8TPro-939 socket. Has SATA support. I bought a nice 160 SATA drive. I installed everything, had a few problems, but then I went to install the SATA drive. Now before I did that, I hadn't reformated yet to finish some things that I forgot. So I wanted to check out the drive. I used the tools that came with the drive, it showed up perfectly fine. Even formated it and whatnot. Then I had to reformat my drive with winxp on it. I decided to put it on my new SATA drive. So I load up XP in DOS etc... Go to reformat the drive, but for some reason the SATA drive wont show up in the Bios screen where its suppose to show CH1SATAMaster/Secondary drives. Nothigns there, but the screen PRIOR to that showed the drive. It even came up in BIOS. So I figured it was driver issues. But at this point I couldn't realy do anything cuase I had formatted my drive. So went to just screw it formatted my old C drive and put windows just so I could get the SATA drive recognized so I could install windows on IT. installed windows on the old drive, installed basic motherboard drivers, SATA did not come up. Went into bios didn't even come up in the bios. I then put the drive cd in and did diag, it came up with an error but no specific info. After with some bios fiddling we got it to show up as the promise mode 579 just before its suppose to show it as master drive 0 etc.. Still wont show as a drive. Wont even come up when I use the diag tools from this CD. It is just not there. Yet it is. I'm so bloody confused I dotn know if I just blew my damn drive already, and I didn't do anything except check the cables to make sure they were still in after reformatting it, up to now. So could use some help at this point.
