Help with RPCC.EXE spyware help
Jun 20, 2003
150
So i did some hijackthis scans and found rpcc.exe(a spyware aquanted with spysheriff) which hijackthis states is a running process located in
C:\Windows\system32\Rpcc.exe
although when i get there i cant find it, and i also cant find it in the hijackthis list of operations on my computer.
I attempted to disable hidden folders and did a full computer scan for it including the hidden folders/files althouggh to no avail.
But according to hijackthis its still a running process and its still on my computer and when i open task manager and check out my processes its still there everytime i reboot.
Im on windows xp by the way.
CAN someone please telll me how to remove this!!
Jun 20, 2003
150
Thanks guys, i did try scanning with spybot and adaware and norton and they all failed although i booted it up in safe mode and it magically showed up, so thanks for all your guys help!
