Hey, I just picked up the DLINK DIR-655 to replace my NetGear WGR614 router.
First thing that happened was that I could not Remote Desktop into work. All other things worked, ( I did not check my XBox as I had to get online with work that day). Connected al my computers to it and the only computer that I could connect to was my Windows Home Server. I could not connect to any other computers inside my metwork or work. I connect to work using a VPN connection and it didn't work at all, but I could ping the computer from the command prompt.
Second I went out and researched, and then opened up the Port Forwarding rules for port 3389, the default port for RDP.
Thirdly I contacted DLINK support and that was a joke, no help at all.
Fourth, I reconnected my old router which doesn't have the port forwarded and for some reason I can now connect from all my computers.
What am I doing wrong? I think it has something to do with the DLINK but I am not sure. Could it be that my Netgear didn't do it right?
Is this normal? If it is, how do you make it so that every computer can remote into each other and to the outside?
