I install riva tuner, but it wont let me adjust my speed settings on my 6800GT. I had coolbits installed, but I reinstalled my graphics drivers to get rid of it, but it still wont work. ANy help?
Uninstall your graphic driver then use drive cleaner to remove the remnants before you reboot.
Reinstall your graphic driver and use coolbits 2 to overclock.vHere
