Trying to add a water coler to my ultra card from creative I knock a
resister off. It was a tiny sucker that is black on top and says 150 or 750,
i think 150. I think i killed it when it stuck to the solderiron for a few
secs. Anyways i did get it replaced{soldered]. if its dead it isnt working
but the card is fine. although the memory feels very warm .The sinks fell
off while a go do to a shoddy placement . I really cant say I have felt the
sinks before if they are normally warm or du to the resister problem.
Anyways If some one could tell me about what the resister does with those
numbers ,And if they can shed some light on my little problem.
My card runs fine at 250 /500 memory just fine since i got it.. .
Thanks,
Randy
Thanks,
Randy
