- Feb 29, 2012
- 4
- 0
- 0
Hi.. I'm having trouble with this, if anyone could help, I'd appreciate it.
at the beginning I got the security check virus... thought I'd gotten rid of it, but my comp continually froze up or lagged badly and the virus was constantly redirecting the browser. so after getting tired of this I attempted a factory restore (not system). well I wasnt able to access the factory restore and so I started looking online for an answer to how to fix this. Other forums I've been to tell me to go to dell for support. there IS no support from dell.. pfft.. please help if you can.
>>>>>>I STARTED WITH THIS:
Download Hiren's BootCD from http://www.hirensbootcd.org/download/
Burn Hiren's BootCD to a CD
Put the Hiren's BootCD into CD Drive and Reboot computer
Select "Mini XP" from the menu
Double click on "My Computer"
Identify the partition that you use for your operating system
Right click on that partition and select "Format" to ensure a clean install
>>>>> ALL THIS WORKED FINE!
Identify the recovery partition and go to the "Imaging" folder
Right click on the "Imaging" folder and select "Command Prompt Here"
At the command prompt type (substituting c for your particular recovery partition and e for the partition that you use for your operating system)
imagex /apply c:\dell\image\factory.wim 1 e:\
>>>>AT THIS STEP IS WHERE I RAN INTO TROUBLE AND GOT THIS ERROR: imagex is not recognized as an internal or external command, operable program or batch file.
I'm not sure what to do now, because there IS a factory.wim file at this location. Please, any help would be appreciated, thank you!
Thread moved to Computer Help forum, per suggestion by oynaz.
Harvey
Senior AnandTech Moderator/Administrator
Harvey
