Help with .reg file for w7
baconlover
Hello Anandtech!
I have written a .reg file and was wondering if it is correctly formatted and if it will do what I want it to.
Code:
Windows Registry Editor Version 5.00
[-HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run]
[-HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
[-HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
@="explorer.exe"
I want the first 2 lines to delete the entire keys. The 3rd line I want to delete only the value attached to the key while the 4th line should add the value explorer.exe
Does this look right to you?
Thanks in advance!
