Help with recording from my HDTV needed...
keezy
I have an LG HDTV (32LK330) and a Toshiba DVDR (DR320KU), and I'm able to watch movies but unable to record. Unfortunately, my HDTV has no outputs to send a signal to my DVDR. How should I go about fixing this?
Any help is appreciated. Thanks in advance!
While I don't have knowledge about these particular models, most HDTVs aren't going to have a video output.
Typically the video source has to go into the recorder first, then from the recorder out to the TV.
If the Toshiba (DR320KU...couldn't find it online) doesn't have a built in tuner, you can't record from the "output" of your TV. Most TV's outputs are limited to the audio (to send to a stereo). I haven't see a modern TV with video out from the tuner.
Whatever you are using to watch movies with, you have to send that video/audio ouput to the video/audio input of your DVDR.
If you are just on cable and have a piece of coax plugged into the back of your TV from the wall, then you can't record to your DVDR this way. You have to pass the signal through it (DVDR) first and then on to the TV.
