Help with RAM problem RE: K8T Neo
bitt3n
I had this mobo (K8T Neo MS-6702 version 1.0) running fine with two sticks of 512 meg PC 3200 DDR. I bought another gig (also PC 3200 DDR) and started running 1.5 gigs (and sold 1 of the 512's, since this mobo accepts a max of only 2 double-sided sticks at the same time).
I then took out the remaining 512 meg stick to sell it also, but the mobo wouldn't boot with just the 1 gig for some bizarre reason. I then put the 512 meg back in, and it wouldn't boot. I took out the 1 gig and now it would boot with only the 512 meg. I then put back the 1 gig and it would boot again, but if I took out the 512 meg it would fail to boot once again.
I had already ordered a second stick of 1 gig DDR so I swapped out the 512 with this but again the mobo failed to boot. According to the D-bracket diagnostic LEDs, the boot process was stuck at 'Early Chipset Initialization', and if I took out all the RAM, it would still get stuck at that place and would also beep three times in succession.
I then put the 1 gig ram back in with the 512 meg, and in that configuration the boot process stops at 'Boot Attempt' which is the last step before 'Operating System Booting'. I then took out the 1 gig and put it back in, and now it gets stuck at 'Early Chipset Initialization' again (the first step after 'Power On').
I have tried clearing the CMOS also. I did this back when I was trying to get the 1.5 gigs to work initially, and they did work after a few attempts, although I don't know if this had anything to do with it (since I also reseated the sticks). Now this has no effect.
I've tried every configuration I can think of but nothing appears to work, and now I can't even get as far as 'Boot Attempt' -- everything ends in 'Early Chipset Initilization'.
Is there anything else that I can try, or is this board dead? If it's dead, can I avoid the necessity of reinstalling windows by buying an identical board?
Given that I need AGP and am using PC 3200 DDR, what's a good replacement mobo assuming I need to replace it and I can't find the same model?
Thanks for your help!
