Help with RAID feature on SOYO DRAGON Plus
ArvinC
Hello everyone!
First off, here are my rig's specs:
- AMD Athlon 2000XP (1.65MHz)
- Soyo K7-V DRAGON Plus
- Nanya PC2100 DDR RAM (512)
- Abit Saluro GeForce 3 Ti-200
- (2) Western Digital WD400BB 40 Gig HD's 7200 rpm
- Lite-On LTD-163 DVD (Black)
- Lite-On LTR 24102B CDR/CDRW (Black)
- Mitsumi Floppy (Black)
- Thermaltake Volcano 6+ Cu
- Arctic Silver Alumina
- Lian-Li PC-65 Case
- Raidmax PMS-400 Aluminum 400 watt powersupply
Not bad, eh? Only problem is, I'm trying to install M/S Windows XP Professional and it won't read my drives when I have them set up in a striped (RAID-0) array. I'm using the on-board Promise RAID controller on my m/b.
Here's what I have done and tried: First, I made sure I had the jumper comfigured properly. Then, in the BIOS utility, I made sure to enable the on-board RAID. Second, I made sure to enable the CDR/CDRW as the boot drive.
When I re-booted, I went into the "Fastdisc" utility, so I could set-up the RAID array. Set it up fine. It confirmed that it was a functioning, bootable array and listed both my hd's as being on the array. Re-booted again, this time with the XP Pro disc in. It loaded up some drivers, then when it went to "Start Windows," I got a screen saying "Windows could not detect any hard drives on your system." Tried this several times, still same problem.
So I tried it without the drives in a RAID configuration, and XP read them fine and asked me which drive I wanted to install on. What gives? Did I miss a step? Or was there a something I should have done differently or not at all?
Any help or advice would be great!
ArvinC
oakfan
39
When XP is loading it should ask you to press F6 (I think) if you have any 3rd party raid drivers. Then when XP loads it will prompt you to put in a floppy containing you raid drivers (you need to copy these to floppy from the soyo cd). Once you have loaded these drivers XP will see your raid setup.
Have fun
drchickenman
20
look on page 92 of the user manual and it will tell you step-by-step how to set up RAID while installing XP - also make sure you are using a newer bios
