Hi folks...
I've decided to add Linux (Mandrake 7.2) & BeOS to my current dualboot
system (W98 & W2K), all seems to be working well, except for this...
Win98 & W2K are on their own FAT32 partitions on my primary hard drive. Mandrake 7.2 is on its own partition on my secondary drive, followed by BeOS in its own partition on the same drive.
Everything seemed to install fine, the Mandrake installer defaulted to grub rather than lilo... but it seemed to boot up & run just fine. The problem started after installing BeOS.
According to the quadboot article at http://www.maximumlinux.com one can use the BeOS boot manager to choose between the Windows OS's, BeOS and Linux... it boots up the two MS partitions just fine, and BeOS also starts fine, but when I choose Linux from my BeOS boot manager I get the following error:
Loading Linux (Mandrake 7.2)
Boot sector signature no found.
Linux still boots up just fine with a boot floppy of course, but of course a boot sector mbr fix would be preferable, and as a complete newbie for Linux & BeOS, I'm stumped... I suspect that I need to somehow restore either grub or lilo, but wouldn't that then overwrite the BeOS bootman? Also, according to the article at the above-mentioned link, linux doesn't need its own boot loader with the BeOS boot manager installed.
Anyone have any ideas?
