Help with Q9550 Overclock
Eddie313
634
Looking for so help i have a Asus Q45 with a Q9550 with a cooler master cooler on it.
Bios Pic 1
Bios pic 2
Bios pic 3
Now i can not get over 415fsb I have tryed different volts back and forth but still nothing.
It runs stable did prime95 for about 30 hours and no errors
Q9550 3.53 Cpu volt at 1.250 EO STEPPING
FSB 415
The ram is ballistix tracer ddr2 800 have it at 2.0 volts
Now is the ram thats holding me back or what i'm i doing wrong?
Or maybe is it just the board wont go higher than 415fsb???
Thanks
I have some pix in bios
Spikesoldier
6,766
use a lower than 1:1 memory divider if available to rule out poor memory. dont be afraid to give it 2.1 or 2.2 though to see if things do stable up for you first. also dont be afraid to give it more vcore either. i would also disable the auto OCer in the first bios pic and c1e in the third pic
May 13, 2009
12,333
612
That memory should be fine with a 1:1 ratio. Its quality memory and should easily overclock up to 900mhz which would give him a 450 fsb speed. I don't know the multi on a q9550, I believe its 9x, but that would give you a 4ghz oc.
Did you try upping the voltage to cpu a little bit? Giving fsb a little more voltage? I liked those Q9XXX chips. I had a Q9400 and ran it @3.75ghz and it was sweet. Of course now I wouldn't give up my i7.
Eddie313
634
Thanks guys i tryed some volt's bump and just can not get it there.
I upped the cpu to 1.35
ram to 2.1 volts tryed 2.2 nothing
Here is a cpuz val link that is now the highest i can go testing prime 95 as i write this.
http://valid.canardpc.com/show_oc.php?id=744309
You said try to lower from 1:1 but the board has alot different setting than my 780i board had or my 790FX board did.
Should i up all the
cpu pll
fsb termination voltage
nb voltage
I have tryed doing a little bump to them but didnt seem to work
Nov 26, 2005
15,197
403
What are your timings for your DDR2 800? 400fsb will be your limit without overclocking the RAM. If you have 4.4.4.12 you can open up the timings to 5.5.5.15 and push for 450fsb....
First I would drop your multi to 6 and run Memtest86 vX.XX to see if your ram is stable at 1:1 ratio. You'll need to burn Memtest to a disc and boot into it. So say if you have DDR 900 then 450fsb would be 1:1 and DDR 800 would be 400fsb at 1:1 and so on. This way you test to see if your memory isn't the problem. After about 3 100% passes in Memtest86 (you can do this longer but i'd do 3 at minimum) boot into windows at the same low multi of 6 and 1:1 ratio of your ram. Mine was 6mulit x 500fsb = 3Ghz in windows. This way I knew there wasn't so much pressure on the CPU and RAM there-by isolating the motherboards subsystem. This is where you test the NB. One of the best apps to test the MB subsystem (NB circuitry) is Prim95 Large FFTs.
Eddie313
634
WoW Thanks
My ram is 4-4-4-12 @ 2.0 volts
My setting right now is
5-5-5-18 2T 2.0 volts
Nov 26, 2005
15,197
403
Here is a guide I made up for a UD3R & a Q9550 but some of the stuff will apply to you... now mind you the UD3R P45 and UP3P boards are thee best quad 775lga socket mobos for overclocking your Q9550... Other board will help you reach 4Ghz but this board gives you fsb headroom to play with... I loved my retired Q9550 setup..
Make sure you have the latest bios first of all.
Now, if you have all dimm slots occupied it will be alot harder running high fsb for something like 4Ghz... my 4Ghz is done by 500fsb by an 8 multi. I am running a 2x2 config & DDR2 1000 so I don't have to worry about hitting a memory wall when trying to overclock; thus 500fsb is my max without overclocking the ram. My Q9550 is almost near the Intel vcore max. In bios it's at 1.375 but with vdroop it is a steady 1.34v and stable.
So, when you start getting blue screens and or not booting into your OS that's when you slightly raise those settings. PLL & MCH (MCH is your NB) would be a good place to start. Then, if you keep failing your boot or blue screen in P95, raise your Vcore: but keep that Termination at a difference of .0500v
With that, you should keep testing till you reach your OC goal. Be careful not to overheat your chip beyond 70*c on the cores. 70*c is conservative but good advice.
You may also want to test your system stability with LinX - maybe 20 or 30 passes at the most memory you're allowed by the app. This will heat your system up tremendously so keep an eye on your core temps. I personally use Hardware Monitor which monitors your core temps and Northbridge temps as well as giving your voltage readings, fan speeds, etc..
If you have any more questions feel free to pm me.
Have Fun and Good Luck!
Eddie313
634
After doing what you guys said i called me buddy and he says that there is a limit it hits the fsb wall at 425 nice :thumbsdown:
So i guess ill have to get a different mobo if i want to go higher.
Thanks for all your help...
Nov 26, 2005
15,197
403
well then, that may be your problem. you may have a wall there, although for some reason i have a hole between 425fsb & 475 anything outside those numbers works well
Eddie313
634
sweet juice to 500 FSB Woohooo lol
j/k
Sucks tho i have a sweet micro lian-li case that i love :{
