I have been playing around with this for a week now and AT&T is telling me there is nothing wrong with the T1 circuit. But I can't get the two routers to connect. Here's the setup and configuration:
Site A: Cisco 2821
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
interface Multilink1
ip address 192.168.0.103 255.255.255.0
ip tcp header-compression iphc-format
no cdp enable
ppp multilink
ppp multilink fragment delay 10
ppp multlink interleave
ppp multilink group 1
ppp service-policy output voice_policy
ip rtp header-compression iphc-format
interface Serial0/1/0:0
bandwidth 1540
no ip address
encapsulation ppp
fair-queue
ppp multilink
Site B: Cisco 2610XM
controller T1 0/0
framing esf
linecode b8zs
ip address 192.168.0.102 255.255.255.0
no cdp enable
ppp multilink
interface Serial0/0:0
bandwidth 1540
no ip address
encapsulation ppp
fair-queue
ppp multilink
The output for 'show interface' on Serial0/1/0:0 is:
Serial0/1/0:0 is up, line protocol is down
Hardware is GT96K Serial
MTU 1500 bytes, BW 1540 Kbit, DLY 20000 usec,
reliability 128/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP REQsent, multilink Closed, loopback not set
Keepalive set (10 sec)
Last input 1d18h, output 00:00:01, output hang never
Last clearing of "show interface" counters 1w0d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1155 kilobits/sec
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
2680 packets input, 61640 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1611885 input errors, 1611881 CRC, 787474 frame, 437505 overrun, 0 ignored, 1181161 abort
137393 packets output, 4104436 bytes, 0 underruns
0 output errors, 0 collisions, 13612 interface resets
0 output buffer failures, 0 output buffers swapped out
14 carrier transitions
Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
The output for 'show interface' on Serial0/0:0 is:
Serial0/0:0 is up, line protocol is down
Hardware is PowerQUICC Serial
reliability 184/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP Listen, multilink Closed, loopback not set
Last input never, output 00:00:28, output hang never
Last clearing of "show interface" counters 1d16h
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 8952 giants, 0 throttles
11807 input errors, 667 CRC, 4867 frame, 0 overrun, 0 ignored, 6273 abort
29180 packets output, 875400 bytes, 0 underruns
0 output errors, 0 collisions, 7819 interface resets
3 carrier transitions
Site A: Cisco 2821
controller T1 0/1/0
framing esf
linecode b8zs
no cdp enable
ppp multilink
bandwidth 1540
no ip address
encapsulation ppp
fair-queue
ppp multilink
controller T1 0/0
framing esf
linecode b8zs
no cdp enable
ppp multilink
bandwidth 1540
no ip address
encapsulation ppp
fair-queue
ppp multilink
