Help With Power Supply (or I think that's the problem)
guynamedAlex
I just finished assembling a nice Athlon system (Athlon 2200+, EPoX 8K5A2+, DDR366, Thermaltake Volcano 7+ etc.) with an Enermax EG365P-VE (FCA) 350W PSU (which allows for manual as well as Mainboard control of the fan speed) and when I went to turn it on all the lights on the drives lit up and and some of the fans started whirring (wasn't long enough to figure out which, but I have three case fans, two fans built into the PSU and the fan on the CPU) and then everything abruptly stopped. Further attempts to hit the power button were initially futile. I, however, figured out that I could recreate the starting and quickly dying effect by either unplugging the cord from the socket for a few seconds then replugging it in and hitting the power button or by hitting the power button and the power switch on the PSU at the exact same time, which actually gets the computer going for closer to two seconds. I'm assuming this a problem with the PSU. If anyone has any insight or possible solutions I would be grateful.
yakko
25,455
Try removing the board from the case and putting it on a non conductive surface then booting up. It may be a short somewhere else.
LostHiWay
1,544
Take the board out of the case and try it again. Also clear the CMOS and make sure the memory is firmly in the memory slots (you have to push really hard with EPoX boards)
guynamedAlex
Thanks guys. I figured out that it's not the PSU by having the PSU successfully run another one of my (older) comps. However, I tried putting the board on the (wooden) floor and the new PC still isn't booting and the trick to get the lights on isn't working anymore either. I'm gonna start a new thread, since the subject has changed. Thanks again, though.
