My Siemens router has the following fields for configuring special applications....
Trigger port, trigger type (TCP or UDP), public port, public port type (TCP or UDP), enabled/disabled check box.
The sites I find regarding opening ports give infor mation like this:
OUT UDP 6899
IN UDP 6899
or
OUT TCP 1720
IN UDP 1024 65534
I can figure out the enable check box and TCP or UDP but where does the other data go?
OUT UDP 6899
IN UDP 6899
or
OUT TCP 1720
IN UDP 1024 65534
