Hey, i was wondering if anyone has any ideas on how to make the edges on a clear cpu case to be smooth and glossy after beveling them a bit. I dont want the sharp edges. I saw a man just bevel an angle into the edge of a peice of lexan. Then he took a torch of some sort and ran it down the edge after sanding it first and it was glossy like the face. The one thing is....it was black lexan. Would this method work on plexi and will it discolor the edge?
