MainFramed
i dont know if i should go p4 or a AMD ATHLON, i hear great things about these AMD Athlon thunderbird... i just dont no if i should go pentium or athlon, i want a really fast and strong system..please help me😕
Originally posted by: Dr Smooth
It would help if you indicated what your budget is and what appls you intend to run.
Both products will give you a "really fast and strong system".
It comes down to whether you intend to overclock your system or not:
1. Go with Intel if you are going to overclock.
2. Go with AMD if you are not going to oiverclock.
Originally posted by: here4amission
just wondering...(as you can tell this is my first computer that i am building and i am learning about all this stuff) what is overlocking and whats not overlocking? then i will be able to tell more about my postion
