Hi all. It is time for a new computer. I will be honest, I do not need anything special and will be my first PC build. But I'm usually willing to try something new, so why not try a computer build. Here's what I'm looking for:
1. What will YOUR PC be used for
Word, Excel, Powerpoint, internet, e-mail. I don't game, just do those basic tasks. Here's the thing, I keep my computers for longer than I should (my current machine is 8 years old and running XP. Its old, slow, and it's operating system will be retired shortly), so I would prefer something that will stand the test of time by working well over the years (i.e., speed and reliability/durability) as I will likely keep this computer for 6-8 years also.
2. What is YOUR budget
Up to $800 with taxes/shipping factored in
3. What country YOU will be buying YOUR parts from.
US
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
Doesn't apply
5. IF YOU have a brand preference.
No preferences. Just decent performance and durable/reliable. That's it.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I will use my current monitor. It's nothing special, but I rather spend the money on a computer that will last awhile, and then score a good deal on a used monitor (periodically people post a good deal on monitors at work).
7. IF YOU plan on overclocking or run the system at default speeds.
default speeds
8. What resolution, not monitor size, will you be using?
Whatever. I'm not gaming, so this is not of higher importance.
9. WHEN do you plan to build it?
Soonish. As noted, Windows XP will be expiring soon. I have a slightly newer (i.e., only 6 years old I believe) laptop that has Vista, but it too is a little long in tooth.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
I may need Windows. It is possible that I can get it through work through a program worked out with Microsoft. I just can't remember if Windows is one of the options.
Thank you very much!
Dan
US
Doesn't apply
default speeds
Dan
