PLEASE when you POST threads asking for input on system builds tell us...
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
3. What country YOU will be buying YOUR parts from.
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
7. IF YOU plan on overclocking or run the system at default speeds.
8. What resolution, not monitor size, will you be using?
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
LMAOMTDEW ruined my post 🙁
I just assumed he's referring to the 7970 since the other choice he listed is the GTX 770.I'm not sure what Asus MATRIX is... HD 7970 or GTX 580?
Will you be needing an OS?
I will not be overclocking, so the i5 3570 or 3770 would be my CPU preference, anything around there. I will be buying my parts from Newegg.ca as I am canadian. I will not use my current parts, and the Monitor I would prefer 1080P or 1440P at 23-24". The Optical Drive is just to install Windows on, nothing else. I will be building it next month or so.
What is the purpose of the PC? Only gaming?
SAMSUNG DVD Burner SATA Model SH-224DB/BEBE - OEM
Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive - OEM
CORSAIR Builder Series CX600 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
Crucial Ballistix Sport 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model BLS8G3D1609DS1S00
Intel Core i7-4770 Haswell 3.4GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I74770
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
SAMSUNG 840 Series MZ-7TD120BW 2.5" 120GB SATA III Internal Solid State Drive (SSD)
Rosewill CHALLENGER-U3 Black Gaming ATX Mid Tower Computer Case ,comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top
GIGABYTE GV-N770OC-2GD GeForce GTX 770 2GB 256-bit GDDR5 PCI Express 3.0 HDCP Ready Video Card (Comes with Tom Clancy's Splinter Cell Blacklist)
MSI B85M-E33 LGA 1150 Intel B85 HDMI SATA 6Gb/s USB 3.0 Micro ATX Entry HDMI Business Intel Motherboard
ViewSonic VA2342-LED Black 23" 5ms Widescreen LED Backlight LED Monitor
Total (Excluding taxes and fees) : $1,404.89
Given that you are undecided on the video card, I'm going to assume that you don't have one yet.
i5 4570 $215
ASRock H87 Pro4 $85 AR
Team DDR3 1600 8GB $52
PowerColor 7970 $360
Samsung 840 120GB $98
WD Blue 7200RPM 1TB $65
Corsair CX600 $65
NZXT Source 210 Elite $50
Windows 7 Home Premium 64-bit $100
ASUS VG248QE 144Hz $280
Total: $1370 AR + tax
If the monitor is busting the budget too much, then swap it to the VE247H. Note that I didn't include an ODD because you can install Windows from a USB flash drive.
Not too useful without links and prices.
See by sending you from Computer Help to General Hardware. i told you you would get the best:thumbsup: Do i get Air miles points with this:biggrin:Thanks! This really helped! I just won $1000 dollars so I will be switching out the 7970 for an Asus MATRIX HD7970, so this thread will now be unbookmarked by me, thanks for the fast response guys!
