1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
A: Internet browsing, Email, Word processing, Light Multimedia - videos, music, video conferencing. No gaming!
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20%
A: $400 - $500. Also, I live near a Microcenter where CPU's seem generally cheaper.
3. What country YOU will be buying YOUR parts from.
A: USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
A: Partial to Intel only cuz last system I built was a core i7 a couple yrs back. Open to AMD if there is good reason behind it =]
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
A: Monitor, (don't need OS either)
6. IF YOU have searched and/or read similar threads.
A: Went over a few threads and Anandtechs holiday pc building guide.. didn't have the time to read through them thoroughly this time around.
7. IF YOU plan on overclocking or run the system at default speeds.
A: Default
8. What resolution YOU plan on gaming with.
A: N/A
9. WHEN do you plan to build it?
A: ASAP
10. Don't ask for a build configuration critique or rating if you are thin skinned.
A: Not a problem
Thanks in advance guys!
A: USA
A: Default
A: N/A
A: ASAP
A: Not a problem
