- Oct 1, 2002
- 2,304
- 1
- 76
Components:
Logitech Z-5500
HT Omega Claro Plus PCI Sound Card
MSI P67 // 2600K // 16GB Corsair
Optical audio cable (Toslink)
(3) 3.5mm audio cables
RCA cable
I am relatively new to using decent sounding PC audio components, and am a little confused on all the different connections, and what to use, and what components are actually doing any kind of processing.
The way I understand it, if I use an optical cable from the HTO to the Z-5500, the signal is passed from the HTO to the control pod, and it is processed by the control pod. Does this mean the sound card isn't being used at all and is a waste of money?
Second, if I connect the HTO to the Z-5500 via (3) 3.5mm audio cables, is the sound card now doing the processing and just outputting it to the Z-5500 (6-channel direct) ?
Is there a different/optimal setup that any of you can recommend? I just feel as if I am not getting my money's worth having the sound card, as the onboard sound also has an optical out I could probably use and get the same quality. Thanks in advance for any replies.
Logitech Z-5500
RCA cable
