Johnnychangs
Hi
Sorry to sound like such a n00b, but I'm new to overclocking P4 systems (experience with Athlon).
I just installed:
Abit BD7II
P4 1.6a - SL66S Costa Rica - 320SA542-0546
Mushkin PC3200 DDR
Alpha PAL8942 with a Thermaltake Thermal 80mm fan
Coolermaster ATC-201 case
I did the "Wire Mod" on the P4. I think I need to put a bit more Artic Silver III on the P4, because I put a really thin layer on when I installed my heatsink.
Right now, I'm running at default 1600/100. Whats strange is that my Idle temps are 46C. Remember, this is at the default speed. My core voltage is set to default, and displays in the bios at 1.63-1.65v. I tried changing some settings, but really am not sure what settings to mess with.
I did get it to post and boot at:
133FSB
PCI 33 Fixed
16x Mult
cpu/dram 3/4
Vcore +5%
Vmem 2.6
Ram timings CAS2, 2-5-2
Problem was my idle temps were at 51C. I didn't try to push it much because I was afraid it was too hot.
Any advice would be extremely helpful.
Thanks
I just installed:
Abit BD7II
Mushkin PC3200 DDR
133FSB
PCI 33 Fixed
16x Mult
cpu/dram 3/4
Vcore +5%
Vmem 2.6
Thanks
