Right now im running Mobile 2400 at 177x12 (2126mhzat 1.5 volts. I got an ALX800 with a Smartfan 2 at full RPM. Case temps are 27 idle, and they dont rise at all. Cpu is 38 idle, not sure what is load becuase I dont have the thermalprobe from my rheobus hooked up to it yet. (I recently got a rheobus/thermal monitor combo for a 5.25 bay, but dont have it all hooked up yet) If the cpu temp is high, its probably becuase I used too much thermal paste.
Since the fan is at full rpm, its loud as hell. I tried hooking the cpu fan to the rheobus, but the computer only boots up windows when the cpu fan is plugged into the mobo. It gets to the windows loading screen, but then cuts off if the fan is not hooked to the mobo. Any ideas to fix this? (i just fixed this problem, hooked a low rpm 120mm fan to the cpu spot and hooked the cpu fan to the rheobus. I lowered the noise a hell of a lot by lowing the fan from 5100 rpm to 4500 rpm, but it raised temps from 36.5-37 idle to 38-39 idle) Not sure if its a big difference as far as temps go, but its much easier to sleep with. Pretty much all the noise there now is just the sound of air running.
The temps are from Abit Eq software on the Abit nf7-s im running.
I tried using CPU-z (accoring to CPU-z, my voltage is 1.488 also) to find stepping, but all it said for stepping was 0. I already have the heatsink on, and it is a big pain to remove a lot of stuff to see what it says on the cpu. Whats a good program to find the stepping? Also, how are those stats? How accurate is the thermal monitor on the motherboard? Does it over estimate the temps or is it dead on?
