Help with overclocking Pentium D 930...
Bones82
25
I have it clocked at 3750 Mhz now. The multiplier i set to 15 and the fsb is at 250. The motherboard I am using is a Gigabyte 965P-DS3 rev. 1. It says the RAM is at 3:4, 333 Mhz, and 5-5-5-15 timing. The core voltage is at 1.296. The RAM is Corsair 5400C4-667. It is running at 1.8v. The CPU temp is between 50-54C. This has not changed much at all. Stock was a few degrees lower. I am running a Arctic Freezer 7 on the CPU.
Markfw
May 16, 2002
27,416
16,275
My best guess that nobody is overclocking these chips anymore, as the C2D's have been out for over a year. I had a couple of these D'd, but sold them a year ago, and I can't remember much about OC'ing, except I had mine to 3.5 I was hot as heck, and I dumped them as soon as I could.
Denithor
6,298
23
Well...you have a cpu that is already 25% overclocked, which isn't bad for those old furnaces. What more do you want/need/expect?
And you didn't ask any questions...
EDIT: Now, if you really want a performance increase, pick up an e2180 ($75 at ClubIT) and you can probably hit 3GHz with your current setup. Let me tell you, 3GHz with a C2D chip is lots faster than 3.75GHz with a Netburst chip.
error8
3,204
Yeah, that is a great advice since your motherboard supports these cpus. It will run cooler, faster and will overclock like a beast.
Bones82
25
I guess I was just trying to squeeze all I could out of my old chip. It performs pretty well. I am getting around 5500 points on PCMark. What would I get with a E2180?
error8
3,204
It does 4537 points at the cpu test in PCmark 2005, and this on the stock clock of only 1,8 ghz. Just think how much of an increase you'll have at 3-3,2 ghz. Anyway, these synthetic benchmarks don't mean much. In real world applications you'll surely see an important increase in performance.
link: http://www.xbitlabs.com/articl...ium-e2160_8.html#sect1
Mondoman
356
Check out the Pentium D 9xx prices on ebay -- I bet you could get close to $100 for your CPU. Not bad when a new e2160 is around $70.
