help with overclocking a barton 2500+
what would be the mem timings to overclock my pc to 3200+
mobo: epox 8rda3+
proc : AMD barton 2500+
mem: corsair XMS pc 3200
vid:radeon 9600
thermaltake silent boost heatsink and fan
2 blue cathode tubes
5 blue led case fans
thermaltake case
1 WD 120 gig HD
1 WD 80 gid HD
For some reason I doubt thier stock numbers on some of those chips, they have 20,000+ 2.4C's??? does Intel even make those chips anymore?also 970 P4 3.2 EE's @ $965 is close to a million bucks of just those. Kinda weird.
Corsair's XMS will almost always do 2-3-3-11, which is very good performing timings. Don't worry if you're forced to run it at 2.5-3-3-11, though, it doesn't make a huge hit on the performance of the AMD's, like it does with the Intel's. By the way, JBT, wtf?😀
HUH!?!😕😕
Originally posted by: andjayik
what about me-A7N8X Mobo
1024 pc3200400ddr corsair
XP 2500+ Barton
what settings should i try to get 2.0ghz?
Jack the FSB up to 200, then up the Vcore to about 1.725-1.75. It will probably run just fine at 2.2ghz if you do that. I also had to up the vdimm to 2.9 to get my Corsair XMS 3200 to run at tight timings.
set the memory timings to auto so you don't get any memory overheating (happened to me), then just raise that baby to 203 (203 is the last timings before it'll make you hit 9-4-4-3.0 (8-3-3-2.5 is significantly quicker than those timings).
my memory settings are sdram active precharge delay 8
ras to cas delay 4
precharge delay 4
cas 2.5t
are these correct or do they have to be cahnged in order to work better?
1024 corsair value select
