Help with overclocking a 6700K on a laptop
Berryracer
2,779
So my EUROCOM Sky X9 laptop has a desktop 6700K CPU
I have delid the CPU and put Liquid Ultra between the CPU and IHS and my idle temps went down by 5C now at 39C
The problem is, there seems to be something wrong with my settings because, the moment I start a stress test using AIDA64, the temps go up to 88C almost instantly then reach 95-99C within a minute so I am afraid that maybe my power limit settings or IA/Current is wrong
I understand that a stress test will tax the CPU but jumping from a 39C idle to 95C+ seems kinda wrong
If I lower the voltage, I would get random crashes if I open multiple tabs in Chrome or run a stress test. If I increase the voltage, the CPU overheats even more causing thermal throttling down to 3.5 GHz so I am at a loss here
Here are my BIOS Settings:
http://forum.notebookreview.com/thr...enix-has-arisen.781814/page-469#post-10212816
PS: I have ordered a Silicon Lottery 6700K that is guaranteed to run @4.8 GHz but until that arrives, I want to see if you can help me see what is wrong with my settings
BTW, Turbo Power Max @ 115000 means 115,000A
VR Current limit @480 means 480/4 = 120.
Burpo
4,223
473
A different chip's not gonna help your heat problem. There's a reason you don't put desktop CPU's in a laptop. IMO, you'll never reach the full potential of the chip.
Burpo
4,223
473
And if you read that thread, they're all fighting throttle issues when overclocking.
LTC8K6
28,520
1,575
Owner's manual seems to indicate that overclocking support is thru the Intel XTU utility.
CPU Overclocking Support
You can
enable overclocking support for systems with
Intel® Core™ i7-6700K (4.0GHz) & Intel® Core™
i7-6600K (3.5GHz) CPUs
. However to support overclocking for this CPU you will need to install the
Intel(R)
Extreme Tuning Utility
which is provided on the
Device Drivers & Utilities + User’s Manual disc
Note: Systems with i7-6700K (4.0GHz) &
i7-6600K (3.5GHz) CPUs Support Intel®
XTU Overclocking.
Berryracer
2,779
It's an 11 pound "laptop", and they claim to be able to run the 6700K at 4.7ghz:
http://www.eurocom.com/ec/benchmark(98)ec
Look at this thread, most people are running 4.5 - 4.8 GHz on this same laptop so I thought something is very wrong with my settings because the temps are great when idle/surfing the web, the moment I run AIDA64 the temps jump up so high reaching 95C within seconds....
I can't wait till I try that Silicon Lottery delidded CPU I hope I can achieve better but for the mean time, I wanted to ask you pros for any suggestions with my current/power limits or voltage.
I tried settings the voltage to static from adaptive @ 1.185V but the temps are way too high when stressed
PhIlLy ChEeSe
962
This thread shows you have more cents then brains, as stated there is a reason WHY people buy DESKTOP COMPUTERS. You should go hang at TOMS HARDWARE they need people like you..
