I used to use prime95 but hot cpu tester seemed to get my cpu hotter than even prime95 so thats why I began using it. They both do the same thing, run intense cpu pushing calculations and compare with known results to determing if your CPU is erroring out. I can get an error from cpu hot tester quicker than i can from prime95 thats why i began using it for stability testing.
I've tested my cpu with cpu hot tester, memory with memtest86, and video card with 3dmark...what do you mean I havent tested anything? I am open minded to any suggestions that you may think it is.
I think you may be right on the voltage thing. Since i'm at 2.1ghz at default voltage and it seems stable from all tests, I think I will stay here. While I'd like to run at 2.4ghz, the 300mhz wont kill me. Whats more is that since i'm not pushing the voltage the cpu doesnt run as hot so I can run my system with less fans and more quiet. I think I found a good compromise for the time being. I still didnt understand why 3dmark would fail but cpu hot tester wouldnt even tho my video card is not being o/c'ed.
