Help with Optical Desktop Elite with Bluetooth
MrBossman
I need some help please. I recently bought the Microsoft Optical Desktop Elite for Bluetooth (mouse and keyboard) and I've followed the instructions explicitly. I loaded the software, plugged in the USB dongle, and ran the "add bluetooth device" wizard for both the mouse and the keyboard. (Note: my cd has version 5.2, and as a troubleshoot, I got the newest 5.3 software for both).
When I run the add wizard for the keyboard, I tell it to choose a passkey for me, then I type in the passkey, press enter and it tells me the device has been successfully added but the device does not respond then nor after a reboot. The device is shown on the connected devices list.
As for the mouse, I ran the wizard, added the device and it finds it, but does not retain it in the list of connected Bluetooth devices. Same situation as keyboard: successful and will not respond.
I had another regular wireless intellimouse that was using JUST the XP driver (not the software) but I have since disconnected to eliminate that.
My current setup: AMD Athlon64 3200+, ASUS K8V SE DELUXE, 1 gb Patriot XL 3200 RAM, 128mb GeForce 6800 vid card, 60 GB HDD, & Windows XP w/ SP2.
The system is finding the stuff, but not configuring it. I just bought this yesterday, and want to get it working otherwise I need to know if I may have to return it BEFORE I submit the rebate.
I've tried Microsoft's site and didn't have much luck. If someone finds something, I'll be more than glad to take a look at it and try it. I appreciate any and all responses, questions, comments, etc. Thanks.
-Bossman
Not familiar with your periphs, but just to check, are there certain channels you can use.
For instance, is the dongle set to receive on 2, but the periphs send on 1...... if you see what i mean.
No known switches on the dongle. It looks just like a USB Drive with no switches. My last mouse was a regular wireless Intellimouse that used basic Radio Frequencies with a button on the base unit and the mouse it self to match the frequencies. Now if this is a software matter...that's something I don't know.
