I recently bought a case with a 300W PS and a Gigabyte 7ZMMH mobo. Installed a 1GHz Athlon t-bred and 256MB RAM. I have a 40GB hd with no OS on it, no floppy, and an old 1X CD-ROM drive.
The mobo has integrated video, so I have no other cards installed. I have the hard drive on primary ide as master, and the CD drive on secondary as master.
I get really inconsistent results when I boot up. Sometimes I'm able to get into the BIOS. It can detect the hd and CDROM okay, but it gives weird results for the listings for extended memory (like 7MB or 11MB -- seems to vary).
At this state, I can navigate the entire BIOS and set stuff.
I set the BIOS to boot from CDROM first and IDE-0 second. I get prompted to press a key to boot from CD. I have my Windows XP install in the CDROM, but it won't install. Sometimes I get an error saying there isn't enough extended memory. Other times it just goes black and does nothing.
I tried swapping out the CDROM drive for a faster, newer one, but when I do and try to go into the BIOS, if I enter into one of the subsections of the BIOS it locks up and only displays part of the information for that page. I can't navigate out and have to reboot.
Recommendations for getting this up and running? Should I install a floppy instead and flash BIOS, update drivers, etc? I'd like to install Windows XP from the CD to the hard drive.
Any idea why the BIOS flakes out like that?
Any help would be appreciated. Thanks!
