hello frens...........
I have oced my 2.4 prescott to 3.4 to 3.6... while i running some games or cpu intensive apps... at first it would run find but after somewhile the BLUE SCREEN would appear... i noticed that my temps are all fine.. and can it be the power supply voltage... lousy Power supply.... the voltage i set in bios and the voltage it shows in cpu-z is different... where a lower voltage value are diaplayed in CPU-z... i need to know if my power is the culprit so that i can change to anew better one.... any ideas......????
